Switched power in the trunk?
  • Wishno87
    • 6025
    Anyone know of a good source of switched power in the trunk area of an E30? Would rather not have to run one from the engine bay. Need one to switch on the battery isolator for my camper charging system.
  • R1dd1ck913
    • Jul 2014
    • 382
    Power antenna plug.
    Current
    99 328i (Sold)
    91 318is M50B25TU
    89 325ix (Parted out)
    87 325is (Parted out)
    95 525i (Parted Motor for 91 318is)
    • pandaboo911
      • 2070
      Power antenna would be my guess. There's a wire coming from the radio that provides 12v when the radio powers on to extend the antenna. I believe it's white
      • Wishno87
        • 6025
        Not sure what's going on but on my car the red one has power and the white one has nothing. The red one also seems to be constant.
        It's an 87 325i.
        • StereoInstaller1
          GAS
          • 22679
          Red is constant, white is behind the radio
          Closing SOON!
          Thanks for 10 years of fun!
          • Wishno87
            • 6025
            Is there anything accessible from inside the trunk then? If I'm coming from the back of the radio I may as well come from the engine bay or ignition switch.
            • 101
              • Jul 2011
              • 764
              There's nothing else with switched power in the trunk to my knowledge besides that power antenna connector. As mentioned above, the red wire is constant 12v+, and white wire is switched when the radio is turned on. Assuming you still have an OEM radio or that lead connected to your aftermarket unit.
              101
              The E30 collection:
              1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
              1987 325is - Delphin / Black Sport (son #3's)
              1987 325i Convertible - Triple Black
              1989 325iX Coupe - Diamondschwarz / Black Comfort
              1990 325iX Coupe - Sterling Silver / Grey Sport
              1981 Fiat 124 Spider 2000 - Green / Tan
              1998 Volvo V70 GLT - White / Tan
              1998 Volvo S70 T5 manual - White / Taupe
              2001 Ford Windstar - Silver / Grey (parts hauler)
              2006 Lexus GX470 - White / Tan (tow rig)
              • pandaboo911
                • 2070
                Again the power antenna has a 12v signal coming from the radio that tells it to extend. Thats basically switched because your radio will turn on at the key accessory position
                It's not optimal, you may have issues starting the car if your camper puts some load on the battery, because the radio turns off while cranking, causing the isolator to stop isolating, while cranking. If that makes any sense
                • StereoInstaller1
                  GAS
                  • 22679
                  Ya, a typical "isolator" would parallel the batteries, causing the car to drop to the campers level.
                  Run a wire, make sure it stays live while cranking.
                  Closing SOON!
