Hey guys I have a few questions before I start splicing everything. I think I've found where the ignition wire is, but I want to make sure it's the right one and I also want to see if I can pull power from a certain wire. I'll put a pic below to explain everything. I've been trying to find the horn wire with no luck I know it's the brown/yellow wire, but I just can't find it I want the siren and horn to go off at the same time, if someone could point it out that would help out a lot and I was wondering where I should place my shock mount. For the siren would I just connect the positive of the siren to the alarm siren wire? Hopefully this is my last question if I want to test the voltage or current on circuits in the car I should disconnect the negative, then cut and test everything right? I've been following this write up so my wiring looks correct for the alarm itself: http://www.r3vlimited.com/board/showthread.php?t=220237
I believe #1 is the ignition wire, but #2 is the other candidate. #3 looks like I can pull power from it just want to know the proper way to test it.
Thanks for any help guys and happy father's day to any dads out there!
