Injector harness re-wire (need experts plz)
  • Dropped325i
    • Jul 2006
    • 11
    Hello everyone i found out the following info on the harness, i want to re-do the wires that lead to the injector clip on my 325i i6, thi sis what i have for info
    (7 wires)
    Injectors = Red/White = goes to main relay, drivers side, left one in front of the afm..
    Injectors (1,3,5) = Brown/White = goes to ECU # 16
    Injectors (2,4,6) = Brown/Yellow (bigger wire) = goes to ECU #17
    coolant Temp sender (ground) = Brown/Yellow (smaller gauge) to ?
    coolant Temp sender = Brown/Purple = goes to gauge
    Temp Sensor = Brown/Red = goes to ECU # 45 ???
    Temp Sensor (ground) = Brown/Orange = goes to right shock tower?
    I got a couple question marks i'm not sure where to go to, basically grounds, the temp sensor said i think to RH shock tower, bu tcan i run both grounds for (coolant sensor/sender to a body ground into my car so i can have a clean install and harness) if not where do you suggest i connect these grounds? can anyone verify if my info is correct also?
    Thanks,
    Alex L
  • Dropped325i
    • Jul 2006
    • 11
    i'm retarded i can do a continuity test from the ground wires for the coolant temp sensor + switch i currently have to body ground or check the ecu, why didnt anyone tell me this :-?
    • Dropped325i
      • Jul 2006
      • 11
      ah, screw it i'm cutting open the engine harness :) about 75% done... instead of running new wires.. PITA
      • Dave
        E30 RAT
        • 11675
        Current Cars
        2014 M235i
        2009 R56 Cooper S
        1998 M3
        1997 M3
        • Dropped325i
          • Jul 2006
          • 11
          stop stealing my pics, and those rims are gone, and car is dropped.. anyways...
          I'm getting there...just got done doing a head rebuild, 19lb 4 pintle injectors and m30 afm, i think i'm going to relocate the harness instead of going down by the intake just to keep it on top, hers my progress so far, and yeah the other wire taped to the fuel harness rail is a wire re-routed straight to the DME (bought the vehicle like that)
          • Dropped325i
            • Jul 2006
            • 11
            i had to cut the harness up, due to corroded wires for the fuel injection harness etc.. its not done, going to clean it all up later...
