looking for a HU that plays from a USB stick
  • Stanley Rockafella
    • Aug 2011
    • 4060
    Does anything like this exist? If so, what stereos should I look with that have this capability?
    I purchased an old Sony deck in the late 00's that has USB but only plays certain apple products thru the USB port :rippedoff:
    thanks in advance
  • AndrewBird
    The Mad Scientist
    • 11898
    Pretty much every stereo these days does that. I've got all my music on a 32GB flash drive and it's all I listen to.
      • Aug 2011
      • 4060
      the thing is, the deck I have (CDX-GT440U) doesnt' take any of the 8GB flash drives I have. I keep getting the "not supported" message (files saved as MP3's)
      On these lists of compatible devices, nothing is available anymore
      http://esupport.sony.com/US/perl/sup...e=&info_id=270
      http://esupport.sony.com/US/perl/sup...e=&info_id=572
      sucks since I bought this thing in 2010, and already it's useless. I mean, I sure as hell ain't gonna start burning MP3's again:rippedoff:
      • rmdashrf
        • Feb 2014
        • 207
        i bought this recently:
        http://www.amazon.com/Pioneer-MVHX56.../dp/B00GS80OQ8
        i love it, eff CD's. you can color match the backlight. I ran a USB cable into a blank next to the hazard switch. if you can deal with it not perfectly matching, its worth a look.
        • IceWhite
          • Jan 2015
          • 945
          ^How did you mate the USB into the blank, I am looking to do the same. If you have any pics. please post them.
          1990 325i
          2004 330i Individual 6-speed
          • AndrewBird
            The Mad Scientist
            • 11898
            "USB Input: The receiver's front-panel Type-A USB input can be used for plugging in a (MSC) Mass Storage Class or MTP (Media Transfer Protocol) type USB device. The head unit can play music files stored on the USB device in MP3, WMA, or AAC formats (up to 320 kbps). When playing a USB device, the display can indicate track/album/artist/genre number, track/artist/album/genre name, elapsed playing time, text information, or clock. The head unit can recognize up to 128 folders with 500 tracks each when connected to a USB Mass Storage Device. A sliding cover protects the USB input when it is not in use."
            That is on Sony's website about your HU. If it can handle 500 tracks, then the size of the drive is likely not the issue. I'd try format your flash drive and putting the music back on it. Format it with a FAT file system instead of NTFS and see if that works. Also make sure the music isn't in more than 128 folders (many transfer programs create a folder for each artist).
            • rmdashrf
              • Feb 2014
              • 207
              There, top right. I rearranged everything up there so the USB drive wouldn't get in the way. The piece I ordered:
              http://www.amazon.com/gp/product/B00...ilpage_o02_s00
              I cut it out with a dremel, and then filed it smooth with a bit of chamfer to ease entry (lmfao). I also painted the screws black with Wurth trim paint.
              Both the aux and USB ports are rear mounted. I originally had got a mountable aux and had that in the blank where the switch is now, but ended up moving it to the glovebox. I don't use it anyway, I Bluetooth everything.
              A note about Pioneer headunits, they don't have power antenna leads like most other units. They tell you to use the amp signal lead. What that means is that every time you turn on the radio, the antenna goes up, no matter what input you use. I couldn't take it, thus the switch in the other blank. This will prove to be a problem when I add an amp in the future.
              • IceWhite
                • Jan 2015
                • 945
                ^After looking at the pic of the USB cable in the Amazon link you posted, it makes sense. I didn't know that type of cable with mounting screws existed. Thanks for the explanation. "Chamfer" lol.
                Looks good!!
                My headunit has the dual rear mounted USB ports, and yeah bluetooth FTW.
                As for the amp signal lead, you could splice the power for amp turn-on before the antenna switch.
                1990 325i
                • rmdashrf
                  • Feb 2014
                  • 207
                  ^^^ yeah, I was thinking something like that.
