Crap reception with Z3 antenna...normal?
  • phenryiv1
    • Jul 2009
    • 3246
    I get really crappy reception with my Z3 antenna. I have the 12V+ and ground hooked up but the reception is so bad that I can't get stations more than 20-25 miles away (and I am in an uncluttered market).
    Is this normal?
    Patrick Henry
  • fresh_TD
    • Aug 2013
    • 2457
    Because you probably are running a stubby antenna. The longer the antenna, the better the reception
    Sent from my Samsung Note 4
    '91 318i (Alpine) - daily
    '88 325ix (Zinno) - drive here and there!
    • phenryiv1
      • Jul 2009
      • 3246
      If that is the culprit I can use a longer antenna. I don't care much about the looks- I only went Z3 because my stock one had a bent mast and dead motor.
      Patrick Henry
      • beta14ok
        • 283
        I'm running a 16" mast with mine.....all is well with the reception.
        • AndrewBird
          The Mad Scientist
          • 11897
          Might double check the antenna is still plugged into the stereo properly.
          • phenryiv1
            • Jul 2009
            • 3246
            It is. That was the first thing I checked.
            Patrick Henry
            • rcsoundn1
              • Nov 2012
              • 3361
              I still have fine reception. Did you replace your antenna wire? I know your end was cut off at some point. I wonder if there is a cut/break in the wire.
              • phenryiv1
                • Jul 2009
                • 3246
                It was replaced, front to back. The current wire is unbroken and complete.
                Patrick Henry
                • rcsoundn1
                  • Nov 2012
                  • 3361
                  Makes me wonder if the h/u is faulty? If I recall this was not an issue before correct? Same HU just antenna wire swap and z3?
                  • phenryiv1
                    • Jul 2009
                    • 3246
                    No, this HU was the only one I have had in the car.
                    I had no antenna at first, then I rigged up the antenna using the original cable, which the PO had cut the connector off of.
                    I then switched out the cable for a new one.
                    At no point have I had a reliable signal, but I expected that that was because I had cobbled together the connector with the original cable. Unfortunately, swapping cables had no real improvement.
                    I did not care too much because I was using Pandora on my iPhone but the new IOS update has rendered the iPhone unable to connect with my HU in either Pandora or iPod mode. It also will not connect in my daily driver so I know it is the phone but at least in my daily the radio works properly.
                    Patrick Henry
                    • rcsoundn1
                      • Nov 2012
                      • 3361
                      HMMM, Then I wonder if the HU is to blame. I have had HUs that had just terrible reception before. Do u have an extra to try a swap?
                      • Gooch
                        • Dec 2006
                        • 1674
                        I get pretty crappy reception also with the ti antenna and OEM mast.
                        '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
                        '87 535i - Vacuum brake conversion [SOLD]
                        '93 525iT - 5-speed swap - 320k and counting
                        '09 328xi - 6-speed
                        • rcsoundn1
                          • Nov 2012
                          • 3361
                          I have a stock antenna I do not think I will be using. Let me verify it functions before I say anything else but if you have any interest in it LMK. I think some antennas have differnt plugs so we would need to check that 1st, as well as operation of it. I do recall I had a pioneer p1r?? HU years ago as I said before that just had crap reception. EVERYTHING else about it was far above par.
                          • Das Delfin
                            • Sep 2014
                            • 2293
                            The center lead in my antenna wire was super super thin and I could see how you might have a hard time getting a good connection. That being said, the longer the antenna the better reception you'll have. I bought a $10 two foot mast antenna from advance auto when I was trying to get my antenna to work and its reception is great. I have a Pioneer ipod radio if that matters
