C136 Removing Pins
    C136 Removing Pins
    Previous owner cut the two wires leading to the C136 connect in the glovebox. Does anyone know how to remove the male pins? Thanks in advance.
    Build Thread
    I destroyed the connector but for future reference.
    The connector consists of two sliding halves. To disassemble, spread apart the two tabs located where the two halves meet. Ensure the hooks lock into the grooves of the other half. At that point, you should be able to pull the pins out towards the wire end of the connector. It helps if you rotate the pin as you attempt to remove it.
    Build Thread
