The infamous fuse 21 problem
  • sheldpaugh
    • Apr 2016
    • 36
    Buying a 1988 320i tomorrow and it has an electrical problem. Radio, tach, obc all don't work, you know the typical fuse 21 problem. Anyway, he's already tried changing the fuse, it just pops as soon as he puts it in. He says he's searched the typical areas for shorts except for behind the radio which is the factory one I believe. Anyone have this problem and know possible fixes? Could the SI board cause this? Thanks
  • M3and2002
    • Jul 2009
    • 48
    I just went through this with my son's 86 325es. Mine turned out to be the reverse switch in the trans had shorted out by getting oil in it. Just pull the shifter boot up and there is a connector with the two wire going into the rubber sealing boot, disconnect the connector. Replace the fuse and all should be good. If that works replace the reverse (back up light) switch and reconnect the connector above.
    • sheldpaugh
      • Apr 2016
      • 36
      Where is the switch located? And is this what you are talking about? Post #8
      • 2002jm
        • Sep 2005
        • 2076
        yes
        Had the same problem with my h26. When you pull the shift boot out, you will see the wiring harness. If it touches to metal, you will lose the fuse:)
        jm
        • sheldpaugh
          • Apr 2016
          • 36
          jm
          Glad to see that this is such a common cause for it, don't know if the owner checked there yet but I'll check again once I get it
          • 2002jm
            • Sep 2005
            • 2076
            yes
            It is a direct short, if the wires are touching. So every time you turn on the key the fuse will blow:). Makes it sort-of hard to check to see what is happening. Mine did not look too bad, but the wires were pressed against the body and that is all it took to short. pretty easy to rewire.
            jm
            • sheldpaugh
              • Apr 2016
              • 36
              jm
              Thanks for the help! Also, did you have battery drain problems because of this?
              • KyleDriver
                • Dec 2014
                • 14
                had the same exact problem in my '87, as soon as I would put the car in reverse fuse 21 would blow. everyone that posted here is spot on, my reverse switch wires were frayed and contacting the chassis causing a short. I repaired the wiring, problem went away immediately.
                good luck.
                • sheldpaugh
                  • Apr 2016
                  • 36
                  **UPDATE**
                  Got the car today, buddy only checked the wires by the drivers door, will check under shift boot tomorrow!
                  • flyboyx
                    • 8371
                    good luck man
                    Gigitty Gigitty!!!!
                    • sheldpaugh
                      • Apr 2016
                      • 36
                      **UPDATE (again lol)**
                      Disconnected the connector under the shift boot, everything works fine with it disconnected, fuse didn't blow. Thanks everyone for the help, if I could buy you all a beer I would!
                      • sheldpaugh
                        • Apr 2016
                        • 36
                        good luck.
                        So is it the wire coming out of the rubber hole or a wire that's on the connectors?
                        • f4tj0n
                          • May 2013
                          • 411
                          Same wire.
                          • sheldpaugh
                            • Apr 2016
                            • 36
                            Originally posted by f4tj0n
                            Same wire.
                            Realized that after I tugged on it hahah
                            • 2002jm
                              • Sep 2005
                              • 2076
                              yep
                              Had the exact same problem and disconnecting the wiring harness under the boot did the trick. I will go back soon and fix the wires:)
                              jm
