Alright so basically my front driver's indicator only works sometimes, the bulb and fuse are good. I tried pushing on the bulb while it was flashing to give it more contact and it worked fine, seems like the prong is worn, do I need a new assembly? Or is there a simple fix to it?
Indicator problem
You need a new assembly. I had the same problem for a while I used a strip of tin foil to wedge the bulb in and push against the metal prong. It worked for a while so long as you didn't touch it or go over a ton of pot holes.
On a related note, if your blinkers don't work or make good contact the cruise control system will not engage. Weird right?sigpic
1987 325e Lachssilber w/ MarkD chip and late bumpers, Zender EVO spoiler, s3.25 LSD
Originally posted by nandoI don't think there's really strong evidence that ZDDP harms cats.
Originally posted by itsonlygeorge View PostYou need a new assembly. I had the same problem for a while I used a strip of tin foil to wedge the bulb in and push against the metal prong. It worked for a while so long as you didn't touch it or go over a ton of pot holes.
