MiniDSP - Kinda awesome
  • george graves
    • 20003
    So I found this bit of kit called the MiniDSP. It's super cheap($100). and so amazingly flexible. I was planning on buying one and integrating into a headless unit, but honestly I ran out of time - as I have other things to work on. So I hope others might give it a go.
    It's a two channel input DSP with 4 ch out that you can then daisy chain/stack if you need more. You can set crossover points eq, and even do a "room sound " eq, and transfer that map to the eq to get flat response before eq'ing furthers.
    I honestly think this is the most amazing flexible DSP at less then $1000 price I've seen. FYI - I come from a professional large venue sound background, where EQ and normalizing a room is one of the best trick you can do before a larger show before the band hits the stage. This kit, you can even get a $75 calibrated microphone, and EQ your car to perfection. And they make it so easy.
    I'll leave you with this link for more info: http://www.diymobileaudio.com/forum/...ternative.html
    The software lets you adjust every thing.
    Originally posted by Matt-B
  • KrautnotRice
    • Feb 2015
    • 406
    Yep it's very sweet.
    You can also get it already in a case which might be better for cars.
    I was going to get one for my car's build for the ability to run fully active via its electronic crossovers, 31 band LR eq and time alignment (what more do you need?!), then run a stock looking radio to keep it stealth.
    HOWEVER the miniDSP doesn't take high level inputs and the headunit I wanted doesn't have rca pre-outs. So I ended up with the Pioneer Deh-80prs.
    PS: This was the OEM looking headunit: Continental (Kienzle) CD7416U-OR
    It matches our interior perfectly, has amber illumination and a REAR aux in. Just no pre-outs...
    I could've gotten a line driver maybe to convert speaker level to line level but in the end the convenience of being able to tune from the deck with the 80prs vs. having to tune with a laptop won me over.
    '93 300TE 24V Krautbomber
    '84 528e 5 speed Saphirblau Metallic [R.I.P.]
    I love all BMWs with round headlights!
