318is speedo not working
  • nroye30
    • Jul 2015
    • 31
    Ive replaced the speedo and it still isnt working. Moved on to the diff but it is a swapped 3.91. Is this sensor the same as a 4.10 or 3.73 normally on the 318? Thanks
  • Das Delfin
    • Sep 2014
    • 2293
    should all be the same.. the diff itself has a gear which talks to the speed sensor
    Providing you've tested the speed sensor, your next step is to test the fuse(s) for the speedo
