Airbag vs. Non-airbag ignition switch
  • knick_knack
    • Jun 2015
    • 16
    Airbag models have a different ignition switch part number then non-airbag models (RealOEM has them listed as 61-32-1-374-969 and 61-32-1-374-967 respectively).
    My car came with an airbag, but the PO replaced the steering wheel with an m-tech wheel with no airbag. Does it matter which ignition switch I get? I assume the airbag model has connectors for the airbag, so if I had an airbag that I wanted to work, I would need that part. But seeing as I don't need those connectors, can I just get either and not use them if I get a part that has them? Or will only one of them fit into the steering column or harness on my car?
    I've searched and found this question asked a bunch, but never answered:
  • 17sd
    • 158
    I changed my airbag column to one without, and the airbag ignition switch plugs right into the non-airbag column.
    I am not sure if that information helps though.
    • knick_knack
      • Jun 2015
      • 16
      I just bought the airbag one. I'll update with results for future searchers.
