would Infinity Reference REF-5020cx tweeters fit in OEM tweeter pod\
  • NYCDelphin
    • Aug 2016
    • 223
    I am thinking of using the Infinity Reference REF -5020cx component speakers and plan to use the tweeter in the oem tweeter pod.
    Does anyone know if this will fit?
  • NYCDelphin
    • Aug 2016
    • 223
    so, lets put this another way.. what is a good set of components which will fit in the oem tweeter pod ?
    • NYCDelphin
      • Aug 2016
      • 223
      I can confirm that it does.
      • george graves
        • 19996
        Alpine type r's do as well.
        Originally posted by Matt-B
        • NYCDelphin
          • Aug 2016
          • 223
          • bobdavisnpf
            • Apr 2017
            • 56
            I was impressed how big the tweeter pod is in that little window triangle. Mine was glued in super hard; I had to drill out the plastic it was stuck to using a dremel with a needle bit.
            • george graves
              • 19996
              Yea, apparently there is an "easy" way to do it. I didn't want to use heat, cause that can mess up plastic fast. Maybe a hair dryer would be ok, but a pro heat gun, forget about it.
              It took me a good hour to get all the plastic out of the way, and then I made some adapter ring on my laser cutter, and fit as sung as a bug.
