E30 Electrical help
  • Fasteddie222
    • Feb 2015
    • 230
    E30 Electrical help
    First off a picture of my baby
    Ok so my car keeps blowing the fuse #20. The cruise control doesn't work and the temp gauge is a little out of wack. Last thing is that the left turn signal blinks fast then blinks normal and vise versa. What could it be.
    AC blower blows but turns off as soon as I press the snowflake
    Sorry, we couldn’t find that page
  • blackmist27
    • Dec 2016
    • 40
    are you sure your temp gauge is malfunctioning? i would be worried about warping my head if its actually right. you could be overheating your motor.
    • Fasteddie222
      • Feb 2015
      • 230
      I'm pretty sure it's not overheating.
      • hyetide
        • Nov 2008
        • 7
        check your rear left turn bulb socket, make sure bulb is tight, I used pliers to tighten socket, and that fixed mine.
        • george graves
          • 19997
          Ac button worn out. R&R or replace.
          Might be over heating, but tighten the brass nut on the back of the instrument cluster first. Stop driving if that's really the temp you're at.
          Your turn signal bulb is failing or has failed. Replace, clean contacts.
          Originally posted by Matt-B
          • Fasteddie222
            • Feb 2015
            • 230
            Thanks I'll look into it
