Rear left window wasn't working so I pulled it out to inspect. Pulled the motor housing off and no rust, windings look to be in perfect condition. Hooked it up to direct current to see if it would run and it did. Totally fine. Then I hooked it back up to the car wiring and nothing. Then I change the both the front switch and rear switch out and the motor goes down about half way and then stops. Getting nothing now. Not movement or clicking. Changed switches around and still nothing.
Any idea what this could be cuz I'm out of ideas. If the motor worked once when it was put back in then it is clearly getting power.
