E30 Radio kills Rear lights
  • E30_Kyle
    • Mar 2017
    • 7
    My rear lights + license plate lights haven't been working... I pulled radio out unhooked my obc and re-capped some of my radio wires. I then replaced fuse 23 because it blew when I pulled radio out and now my lights work but my radio turns on and doesn't have sound. help?
  • E30_Kyle
    • Mar 2017
    • 7
    any ideas?
    • george graves
      • 19993
      You may have blown something in your light switch. It's a strange beast. Sorry - off the top of my head, that's the best I can do.
      Originally posted by Matt-B
      • E30_Kyle
        • Mar 2017
        • 7
        The lights work now though. The radio just doesn't produce sound. From my understanding they should have no connection to each other other then the illumination which isn't connected?
        • george graves
          • 19993
          What did you change to make the lights work? We're not mind readers here - more info you can provide is helpfull.
          • E30_Kyle
            • Mar 2017
            • 7
            "I pulled radio out unhooked my obc and re-capped some of my radio wires. I then replaced fuse 23 because it blew when I pulled radio out"
            It said what I did in the thread :p
            Edit: Fuse 23 didn't blow till I pulled radio out.
            Edit Edit: Just randomly started working... So confused.
            • 4tDX
              • Jul 2014
              • 506
              Any other weird electrical issues going on at the same time (i.e. slow wipers or windows, o2 sensor warning)? I've not had the exact issue, but I've had similar stuff happen when an alternator was not delivering enough power.
              Anything rewired in the trunk for the speakers or aftermarket headunit? Could be an short of some kind.
              • george graves
                • 19993
                Originally posted by E30_Kyle
                Edit Edit
                I read your post. I was asking what happened to cause that.
                • E30_Kyle
                  • Mar 2017
                  • 7
                  Just randomly started working... No idea what happened. It has wires +/- and ground running to trunk but none of it is hooked up on either end.
                  The edit edit I meant to put radio started working randomly.
