Headlight/dimmer switch repair
  • profbooty
    • 308
    Dash lamps and accessory lamps not working? Headlights still working? You might have a bad dimmer switch.
    If the dimmer stopped working, there is no need to wire a jumper between pins 2 and 6 which would bypass the dimmer function. Do it right, find the discontinuity and repair the switch. Most likely there is a break in the coil somewhere, so if you can't see it, break out your multi-meter and find it.
    To remove the switch follow the directions at this link:
    Once its out, follow the below method to disassemble and solder it. My switch looked a little bit different (didn't have the little barbells), but it comes apart the same way.
    Originally posted by McWattersJ
    Just sourced my similar problem to the rheostat of the headlight switch. It had a break in the coil, so I soldered it .. Testing tonight
    I documented the repair... check http://imgur.com/a/9brdS
