Fog light wiring issue.
  • Sevorith
    • Apr 2015
    • 78
    PO ended up cutting the fog lights off near the fender, so I got a donor harness for the connectors for the fog lights. After splicing up all the wires, the passenger side was inop. I switched the lights around and the passenger side still wouldn't come on. I did a continuity test and had a connection from the fuse to the connector, but I also had continuity from the connector to the ground. I figured the wire was damaged, and tracing the original wire back I found a nick in the wire. I wrapped it up, respliced everything, and still had continuity to the ground. I pulled out the driver side connector and also had continuity to the ground.
    Is this normal? I was under the impression that the power should be isolated and not ringing to the ground.
  • Steve Corbett
    • Jul 2012
    • 449
    There should be two wires, One to power and one to ground. The light connects between them to complete the circuit.
    Steve Corbett
    1983 528E Scrapped
    1983 528E Sold
    1984 745I
    1984 325E - Sold
    1989 325I Bronzit-Sold
    1989 325I Zinno
    1988 635CSI
    • Sevorith
      • Apr 2015
      • 78
      Right, but what I'm saying is should the power wire be ringing to the ground as well?
      • Escaport
        • May 2017
        • 62
        You are correct. The power should not ring the ground. Not sure what the issue is, but ground should only be seen on one of the two wires.
        Current - 1991 E30 325i Auto Vert, 2013 F30 335i M-sport, 2014 F25 X3 M-sport
        Past - 1986 E30 325es, 1988 E30 M3, 1991 E34 535i 5sp, 1991 E31 850i 6sp, 1992 E36 325i, 1995 E36 M3, 2000 E46 323i, 2009 E60 535i, 2011 E90 335d
        • Sevorith
          • Apr 2015
          • 78
          My guess is that it's still shorting somewhere along the run of the power wire.
