Tool size to release pins for C404/405 connector?
  • alpinewhite318i
    • 132
    What extraction tool do you use to release the pins on the C404/405 door connector? Are the pins the same size of the ones in the Molex .062 connectors?
  • earthwormjim
    • Jul 2014
    • 434
    I've always used various sized safety pins for contact extraction, or high quality tweezers (Erem 2SA).
    The extraction tools are junk, unless you spend a lot of money.
    • alpinewhite318i
      • 132
      Yes I noticed the one factory tool is very expensive!
      • AndrewBird
        The Mad Scientist
        • 11898
        All the extractor is is a tube with an ID the same size as the OD of the pin. Get some metal tube from the K&S rack at a hobby shop/hardware store and use that. Buy a few different sizes and use the one that works.
        • alpinewhite318i
          • 132
          Yes I might try the K&S tubes next!
          • george graves
            • 19997
            I use these. https://www.ebay.com/itm/8PCS-Stainl...s/152835331026
            But there are some tools that are made for it. All of them are under $10 and handy to keep in the tool box if you do a bit of harness work.
            Originally posted by Matt-B
