SI Board Woes (New board, no damage, fuse related?)
  • fastestbox
    • Jul 2018
    • 124
    The previous owner of my 318is had the SI board refurbished by Bavarian Restoration about 9 months ago (looking at the board, they did a lovely job)
    My oil change light refuses to be reset along with stomp codes no longer working.
    All of the SI board related gauges work so I know for certain that the board itself is just fine.
    Replacing fuse 10, 12, and 21 fixed it temporarily (about 4 or so hours) and allowed me to jump the diag port to reset it with success. However, it goes back to shining the oil change light and will not allow me to reset it with the side effect of the stomp code ability no longer working.
    Occasionally, pulling fuse 21 and putting the exact same fuse (proving that it’s not blowing the fuses) resolves the problem but again for only about 4 hours.
    I’ve run out of fixes, does anyone have any insight?
    Thanks!
    91 318iS - aluminum M52B28 + ZF320 + 3.15 Torsen
  • earthwormjim
    • Jul 2014
    • 434
    Was the jumper on the SI moved from off to on when the SI board was installed? Without it, power is not supplied to the volatile memory by the batteries.
    • Das Delfin
      • Sep 2014
      • 2293
      I would contact bav rest directly with this issue
      • george graves
        • 19997
        Bav Rest has some killer customer service. This is a non-issue. Contact him.
        Originally posted by Matt-B
