Window switch cleaning gone wrong
  • jackhammer12
    • Jun 2011
    • 133
    So for a while now on my daily 89is, the window switches have been working intermittently. I left out of town for a couple days on business, when I came back they really started to work every so often. Of course a couple more days go by, and we get some more 60 degree days! I forget I wasn’t wanting to roll them down, but cracked one. And now, it is stuck in the cracked position! I read about how you can clean them, so I pulled the little guy apart. I sanded the contacts to all up and down positions. I also pulled out the switch-connector around the spring, and bent the pieces back so they could touch easier! Thinking hey this seems like a cake-walk. Put it all back together, plugged it into the base, aaaaannnnnndddddd nothin. I’m pretty positive the down stil works at this point, but I’m not going to put it any further as snow is around the corner. I pull it out, pop it open once more just to glance if I did something different, everything looked okay! So I gave it the ol nintendo 64 ‘blow out’ and popped it back in. This time, the whole switch was dead. No lights and the down button wasn’t even working. I have a sedan that I believe has a loose contact, blowing the #17 fuse on a daily. So I check that along with all the others, and nothing blown. Did I somehow make the switch worse?? Or maybe I need a new base/connector to wire in. Honestly any input is welcomed, not sure what’s going on 🤷🏻waffles♂️ Cheers guys!
  • Todd Black 88
    • Oct 2007
    • 3449
    Swap switches and close the window. They are all the same.
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
    • jackhammer12
      • Jun 2011
      • 133
      Yep tried that too, still nothing. I’m thinking it’s the base connector part that the wires go into. I’m going to see if I can’t find a diagram and re-work it.
      • george graves
        • 19992
        Is 17 part of the windows? I don't have them memorized. But I do know the window circuit more than anyone
        Originally posted by Matt-B
        • jackhammer12
          • Jun 2011
          • 133
          It is! I initially was under the assumption it coordinates with the power of window switches. On my sedan, you would roll the window down and upon coming up short out and blow the fuse.
          • jackhammer12
            • Jun 2011
            • 133
            Turns out it was just the base! Thanks goodness ��
            • ButtJuice
              • Dec 2009
              • 2609
              I’m sorry to hear about your e30 issue. However if this is your biggest problem with the car, you’re doing pretty well.
              1991 318is - Sold
              1986 325 - Sold
              Instagram - Lamoursum
              • ButtJuice
                • Dec 2009
                • 2609
                I posted before I read this.
                1991 318is - Sold
                1986 325 - Sold
