Any ideas for a decent sub box incorporating a rear stress bar as the anchor?
  • LINUS
    • 2422
    I know we don't REALLY need a rear stress bar - but it would be a great anchor point for a sub box.
    Anybody made a really nice setup to do this? I only plan to run a DVC single 10" and mount my amp on the underside of the rear deck, but if you did something creative post a pic - let's see what you did!
    -B
    It's not how you handle the good times, but the faith you keep in the bad that defines you.
  • StereoInstaller1
    GAS
    • 22679
    1. Please do NOT mount your amp upside down, unless it has a fan. Heat will rise back into the amp.
    2. I had an idea that a box with a PVC tube through it, carefully designed...mount the box and the strut bar at the same time.
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
    • LINUS
      • 2422
      Luke
      Never really thought about that...is it really that big an issue? I do have 2 Eclipse amps that I planned would go there - I suppose I could make a drop down out of stainless tubing to mount upright, would 1/2" clearance between the heatsinks and the tin or the rear deck be good enough?
      Thanks - Ben
      • Morrison
        • 430
        I did this in my 1997 Talon. Basically just measured the space I had available and then constrained the hight to just fit under the rear strut bar. It's a trapezoidal cross section, with a single 12" Diamond.
        "I think we consider too much the good luck of the early bird and not enough the bad luck of the early worm."
        -Franklin D. Roosevelt
        • Morrison
          • 430
          • LINUS
            • 2422
            red x's for me - wanna try again?
            • So Live
              • 2512
              pics no worky
              -Chris
