Really quiet front speakers
  • Rob
    • 8166
    First off I'm not really an audio guy so I may be missing something really simple.
    System: I have brand new kenwood excelon speakers up front, some old cerwin vegas (came with the car) in the rear deck. Clarion head unit, and thats it. Factory speaker wiring AFAIK. The problem is, the kenwoods seem really quiet, even though they are much better speakers. I have to set the fader heavily towards the front to get the sound to somewhat balance. Now I know the factory front location sucks, but does it suck that bad? Also could the factory wiring be the culprit? I have a 4 channel amp and all the wiring waiting for when I have a free, warm weekend, hopefully that will take care of it, but I'd just hate to spend the time on all that just to have to fix something else
    anyone have any ideas?
    BEERTECH
  • Brew
    • 3060
    Higher end speakers sometimes require more power to achieve the same volume as lower-end ones. I would bet that the signal-to-noise ratio of your kenwood fronts is much lower than that of the back speakers.
    AFAIK, crappy wiring won't make your music any quieter, just less "clean". Someone correct me if I'm wrong.
    Im sure it will sound much better once you get that amp and new wiring in.
    '91 318is
    • Rob
      • 8166
      thanks for the input, hopefully that will solve it
      BEERTECH
      • Jonathan M3
        • 1837
        I had noticed this in my M3, i have the stock premium speakers all around and a kenwood cd player and just recently rewired them all and added a 4 channel amp to power them. The fronts sound weaker than the backs before and after adding the amp and rewire, though the speakers produce a much cleaner sound now. I believe it is just the crappy location of the front speakers.
        '05 E46 M3 Imolarot/Cinnamon - CURRENT
        '98 E36 M3 Estorilblau/Dove - SOLD
        '90 E30 M3 Brilliantrot/Black - SOLD
        SRS BSNS Motorsports - 24hrs of LeMons Racer
        • christophbmw
          • Mar 2004
          • 363
          dynamat
          its not only the front location that is making it sound crappy in the front, its the enclosure. on the rear dash behind the speakers it has a sealed enclosure (well somewhat sealed). anyways if you take a speaker and hold in your hand it wont sound nearly as nice as it being in an enclosure. what im trying to say is: if you want better sound you need a better enclosure.
          ....this is what i did: i took the fronts out and bougt some Dynamat (www.dynamat.com) i bought their 2 sqaure foot speaker kit. i then layed that inside the front speaker enclosure(yes it is an EXTREMLY tight fit). it sounds excellent now. you might want to try it. its quit impressive. just my 2 cents.
          '91 318is
          • kencopperwheat
            King of Kegstands
            • 14396
            Re: dynamat
            Can you explain that better? How did you use dynamat to make an enclosure?
            Originally posted by Gruelius
