Any Good?
  • wycoco
    • Feb 2006
    • 723
    Any Good?
    Before my cousin got rid of his car, I took this his amp and sub out the car. I never actually got to hear how everything sounded before he let it go, but he says it bumped. Thing is, I use to have a JL Audio 12" 3v2 powered by a JL Audio 250/1 and it was loud enough already. So I might just end up using one of these subs. At any rate, I'm looking more forward to hearing more input on this amp? Here's the specs:
    vs-1405TWO CHANNEL BRIDGEABLE AMPLIFIER
    MAXIMUM POWER OUTPUT
    300W x 2CH (600W) @ 2 OHM
    POWER OUTPUT:
    130Wx2CH (@ 2OHM) LESS THEN 0.3% THD
    80Wx2CH (@ 4OHM) LESS THEN 0.1% THD
    MONO: 260Wx1CH (@ 4OHM) LESS THEN 0.3% THD
    ALL MEASUREMENTS DONE @ 14.4VDC, 1KHz INPUT SIGNAL
    FREQUENCY RESPONSE 20Hz-20KHz
    2OHM CAPABLE IN STEREO MODE ONLY
    THIS MODEL IS EQUIPED WITH:
    LPF (LOW PASS FILTER) VARIABLE 50Hz-250Hz
    HPF (HIGH PASS FILTER) VARIABLE 2KHz-10KHz
    HIGH AND LOW ADJUSTABLE LEVEL INPUT
    MOSFET DC-DC SWITCHING POWER SUPPLY
    LED INDICATED POWER STATUS
    BUILT IN PROTECTION AGAINST SHORT CIRCUIT AND HIGH TEMP
    TRI-MODE SPEAKER CONNECTION READY
    BASS BOOST (+5dB @ 100Hz)
    AUTO POWER ON/OFF BY REMOTE (+12V)
    DIMENSION: 11 1/8 (W) x 1 7/8 (H) x 9 15/16 (L)
    What'dya think? Any good? I'm not too audio savy, heh. Would this amp just power the subs? Or can it power speakers too?
  • dmoffitt
    • 227
    not really... esp. the sony subs (imho)
    Sold my Sepang Bronze 1990 325is and miss it already
    • wycoco
      • Feb 2006
      • 723
      Paging StereoInstaller. May I get your thoughts?
      Edit-
      I have the Premium iS speakers for the rears.
      Stock speakers for the front, but will be replacing with MB Quart Q-line series.
      I already have tweeters inside the stock tweeter pods.
      I was thinking just running one sub and a connecting the other side to the speakers? Not sure if that even works...help. What's the best way to bring out the best of this system?
      And if it helps, this is my deck.
      • wycoco
        • Feb 2006
        • 723
        bump, please.
