no signals or wipers
  • workaholic
    • Dec 2005
    • 172
    Ok Lets see if anyone has any ideas. I have gotten just about everything squared away on my e30 except for the windsheild wipers and the turn signals. Neither will work. I have replaced all the relays in the main fuse block in the engine bay as well as the respective fuses. Could there be another relay that I am missing?
    Thanks
    Tom
  • netcsk
    • Apr 2004
    • 1609
    did you happen to open up the steering column and check that they are properly grounded (the switches that is).
    • workaholic
      • Dec 2005
      • 172
      Checked the ground at the switch. they are both good at the steering column. at the firewall I was told that they share the same ground with the headlights and they work so thus it isn't a ground issue? in addition the cruise control doesn't work as well.
      Thanks
      Tom
