Right now i just have some lower quality mb quarts with a woofer and tweeter in the kick panel. It sounds good but its not really like in your face sounding. Would getting some other speakers with a seperate tweeter and some tweeter pods help this? and what speaks should i get?
Tweeter pods
Depending on the set you get, you can get pretty good results, not sure what you mean by "in your face". On the other hand, you can make your sound even worse. Generally, you would want tweeters as close to midrange as possible. This way, you would lower your chances of getting multi sourcing, which is having multiple sources of sound. For example: take some cheap MB Quart with a really high crossover point, mount midrange in the stock location and tweeter by your mirror. Given that MB Quart are generally crossed over high and have metal dome dome tweeters, you will be blasted with high frequencies (harsh) in your face and the midrange would be somewhere down there by your feet. Unpleasant to say the least. Music would also feel separated.'96 328is
'97 m3
'04 zhpComment
