Infared tape player wiring?
  • O 16581 72452 5
    • 1066
    Bought a tape player without pictures and accidentally picked up the infared kind, not that i mind, it's way better than the kind for my car. :P But i'm needing help wiring it, there's two clipped wires coming directly out of the back with no way to unhook them, unlike the power, memory, and antenna out, what are these for? Secondly, there's outputs for speakers to all corners, which one is positive, which is negative?
    Any help is appreicated, i could trade it off for the kind with the external fader.
    Edit: I assume the S-video looking thing is for an external CD Changer?
  • O 16581 72452 5
    • 1066
    Bumpy the bumpo.
    • StereoInstaller1
      GAS
      • 22679
      Post a pic of the back. I will see what I remeber.
      I have a shitty memory, that is why I test everything twice!
      Luke
      Closing SOON!
      Thanks for 10 years of fun!
      • O 16581 72452 5
        • 1066
        This is the best i can do man, sorry.
        Background looks great. :|
        • Eurospec
          • 2613
          Is this your first time taking pictures?
          Turn on the flash and point the camera at what you're trying to capture.... simple as that. Not exactly sure why you're having problems with it.
          • O 16581 72452 5
            • 1066
            My camera isn't capable of taking pictures even remotely close to the object, it can't focus on it and it has no manual focus.
            • AndrewBird
              The Mad Scientist
              • 11898
              Your problem isn't that it can't focus up close, the problem is that you aren't pointing it at what you want it to focus, on so it focuses on everything else making what you want clear, blurry.
              Stand the radio on end and take a downward shot of it. Make sure you are in a WELL lit room and it should turn out fine. Pretty much any camera can take a picture of something within 6" of it.
              • O 16581 72452 5
                • 1066
                I've tried it, it's a cheapie camera, it won't focus on anything closer than about 5ft.
                • Eurospec
                  • 2613
                  Have you thought about taking the pictures outside in the sunlight?
                  • O 16581 72452 5
                    • 1066
                    Yesterday, 11:34 PM #4
                    :P
                    • Fidhle007
                      I can fly, motherfucker
                      • Oct 2005
                      • 7209
                      This may help, but it may not. Good luck though!
                      '89 325is S50 Track Montser
                      '04 X5 Daily/Tow Vehicle
                      http://www.avarestoration.com
                      http://www.myspace.com/brendanfiddle
                      Click here if you want to be my zombie slave...
                      http://www.youtube.com/user/Fidhle007
                      • O 16581 72452 5
                        • 1066
                        A little, i need to find the tails...bad.
