how many square feet of sound dediner will i need to do my whole interior and my trunk?
how much dediner
i want to do the whole interior and i wont be using dynamatOriginally posted by christophbmwbuy the dynamat e-xtreme kit. it covored my trunk perfectly, i didnt do behind the rear seat. (im geussing you wont eighther unless you want your bass to go bye bye). i also did not do the spare tire well, i just sprayed it with rubberized undercoat.
you want it under the carpet, up against the firewall, inside the doors, etc?
If you do all that, I'd say you're probably going to use abouut 80sq ft. That's by my ROUGH measurements I just took with tape measure in tara's car for the following:
Firewall
Floor
Doors
Rear 1/4's
Trunk
Sides of trunkMy mountains are better than yours.
What will you be using?
On one of my old cars I used a liquid compound that I painted on. From what I could tell, it seemed like it was mostly sand and oil-based paint. I worked really well. Unlinke dynamat or some other 'stick on' type of sound deadening material, you don't have to worry about cutting little pieces and such, you just paint it on with a brush. I think it was about $80 for a gallon of it. I don't remember the brand name of it, however.Originally posted by Grueliusand i do not know what bugg brakes are.
