All the other parts of the cluster are working
I have swapped numberous clusters and I just finished replacing the tacho within the cluster it self from another one,
I also fixed a bad ground wire on the back in the white plug ,
So far nothing is happening, everything else works 100% as it should ,
I checked with a ohm meter if the tacho signal was indeed there in the black wire on the blue plug and I do get a on and off grounding signal wich is what it should be,
So any help is appreciated
