I can’t figure out what wires to connect to my cd player. I think I know what the speakers are, but I can’t figure out witch wire is for the power and negative. I need some schematics
how to install now cd player . help!!!
Where is your testlight? No installs without testlight, it is the rule.
Brown is ground, white is power antenna.
You need to run new speaker wire to get full power from your new deck.
Welcome to R3V. Did I see your car on Pioneer Parkway (springtucky) last night?
Luke -
On almost all head units, Black is ground, Yellow is switched power and Red is constant power. Then the speaker wires should be Grey, white green and purple, sets of two wires with one having a black stripe (negative). Then there should be a blue wire that connects to either your power antenna or the on input of an amplifier. Hope that helps!
By the way, welcome to the forum!Comment
Oh, wow, you just posted as I did. You also made me realize, redbmw, did you want wiring diagrams for the stock wiring or for your new stereo you are putting in? I posted for the stereo.Comment
to test which wire on the speaker is the positive or negative, use a 9V battery and connect it to the speaker. if it moves towards the outside then you have pos and neg in the right position, if you haven them inverted the speaker will move inward (towards the big magnet in the back)
run NEW speaker wire dud should be easy and for the love of god Make use of your tweeters unless you like NOT listening to music. you can fit a speaker in each door too, look online for wiring instructions becuase most head units have direct connections for only 4speakers and then there's tricks you should knowNo more e30s for me.
88 black BMW OBDII 332is dedicated track [sold]
88 BMW OBDII bronzit 332is [RIP 03/08]
91 BMW 325i [sold]
86 Corolla 'Ae86' HB 20v trd [sold]
http://youtube.com/watch?v=pTj7Hn9v5RsComment
stock
I need stock! the wiring from the car is way diffrent from the new stereo.sigpicComment
