front to rear battery conversion?
  • mck
    • Jan 2007
    • 238
    What do I need to do this conversion?what size cables?
    Ill get a battery tray anf cover soon, anything else I need?
    '89' E30 with Euro S50B30
  • george graves
    • 20003
    Use stock parts. Find someone parting a car and buy the stuff used. Tell them you are retro-fitting the battery in the trunk, so you want the battery tray (I have one avaiable) and cable, trunk plastic sheild, and the plastic mounting block that attaches to the fire wall.
    HTH
    Originally posted by Matt-B
    • Jordan325iC
      • Aug 2005
      • 1697
      You will probably also want the rear battery tie down.
      Also, what car is this going into? When I did the swap onto my cabby, the diffence in the path the cable has to take was enough to make it so that the cable just barely wouldn't make it (less than an inch), so I had to redo the entire swap. I made it work by drilling 1 new hole for the mounting block to the left of the pre-drilled left mounting hole, moving the entire mounting block over by ~2 inches. So I would definately work from the trunk forward instead of the other way around like I did. Also remember to sand down your grounding point, otherwise you won't have a good connection and you'll be very confused.
      '88 325is
      VP UT of Austin Autoholics
      BMWCCA 380364
      • george graves
        • 20003
        ^ Yep! That guy is right!!!
        • backtrail69
          • Jul 2005
          • 4471
          My friend did a battery relocation with zero gauge wire in his 240sx...but I am pretty sure you don't need that kind burly of wire...
          :: PNW Crew ::
          '87 325 4dr, '74 2002
          • ethirdy
            • Nov 2007
            • 406
            I take it the car won't start? (that's what's going on with mine lol)
            Originally posted by alpinaclone
            Since the real economy is in the shitter, I say we start our own.
            This is how it works; you buy my junk, then I will buy more junk and so on so forth etc. etc. Think of the future of your children and buy my stuff.
