hmm not a bad looking enclosure. i like.
front speaker placement
You would be better off building FG kick panels. By sticking driver's in the door you are shortening path lengths between drivers and you ears. If you do that you would probably want tweeters close to your midrange.
On the other hand if you properly deaden/seal doors, they can act as an enclosure for the mid.
So it all boils down to what size of driver you want and what are your main goals. If you're after clean/stealth install- door install would be the way to go. If you're after proper staging and overall sound quality and balance, I'd build kick panels if I were you.'96 328is
'97 m3
'04 zhpComment
lol, sorry I've been MIA from the thread.
yes, I did make them myself. it took a friend and I about 20 hours total (with design and FG drying).
There is a 'skeleton' of mdf, and then we wrapped a sheet around it and painted the FG on.
Because of the grills on the speakers, they probably stick out about and inch past where the OE map-pocket does.
Overall, I'm very happy with them.Originally posted by Grueliusand i do not know what bugg brakes are.Comment
This sounds extremely backwards to me. I'm fighting with my 6.5"s in the kicks right now due to them firing into my feet. I have to balance it to the left quite a bit if no one else is in the car with me. I'll be moving them to the map pocket area this summer.Comment
That means that they aren't aimed properly. You won't be able to fix it as is if you don't have strong DSP. What you are describing of absolutely normal.'96 328is
'97 m3
'04 zhpComment
tho only thing that worries me about making FG kickpanels is the gloveboxYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by TimKninjaIm more afraid of this thread turning into one of those classic R3v moments, where Pizza gets delivered.Comment
i was thinkin about maybe like a 6x9 in the door and a smaller speaker up front maybe a 4Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
donno why i want a 6x9 just kinda thought itd be goodYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
