What side to run wires?
  • george graves
    • 19997
    Passanger side or drivers side? I'm guessing drivers side to keep away from the power cable? Or does it matter?
    Originally posted by Matt-B
  • netcsk
    • Apr 2004
    • 1609
    I always try to run my audio wires down the middle. Otherwise, like you say, keep them away from the power.
    • BENdashdash
      Tom is not my friend
      • Aug 2004
      • 2506
      theres a bulk load of wires running down both sides. down the middle works if you're content with being able to feel wire through the carpet in the back. as for me, i figure theres so much wire behind the dash that will come in contact with the speaker wires anyway. i just ran mine down the sides to make it clean.
      • winstontj
        • Mar 2007
        • 500
        You don't want wires (speaker or RCA) running in paralell with ANY power wires. Things like fuel pump or anything else that is hot in start & run you want to stay away from. You can run your remote switch (blue) with power along the driver's side but what you should do is keep your RCA and front speaker wires totally isolated. To simplify things even more keep your front crossovers under the dash so you have your RCAs going to the back and one each (L&R) for front speakers going forward. This will mean you have a max of five (5) wires down the middle or pass side depending on the car.
        Your remote turn on (blue) can go with RCA & speaker but I like to seperate that because it's power - although it's usually isolated.
        If you run speaker or RCA's in paralell with the big battery wire or fuel pump you will probably get hissing or buzzing (engine noise) in the system no matter how hard you try.
        • Kruzen
          • Mar 2004
          • 5603
          Down the middle worked fine for me.
          Who doesn't love a little BBQ?
          Griot's Garage at a Deep Discount
          • Addissimo
            • Mar 2004
            • 1820
            If you get nice enough interconnects, you can run your wires anywhere you damn well please.
            check out ebay for monster xln pros.
            They rock.
            Doing something M50 related? -> http://www.addissimo.com
            On Myspace? ->http://groups.myspace.com/r3vlimited
            BF2142 SN = BillyGoose
