OEM tweeter help
  • ummagawd
    • Jul 2006
    • 144
    OEM tweeter help
    my driver side door tweeter doesn't work (bought car that way)
    i went to swap the front speakers out for some eclipse and assumed it was just a broken crossover on the stock speaker. But that isn't the case.
    I went to tap the tweeter wire into the other speaker wire for the 4.5,... and it still doesn't work.
    I did this to the other side (tap the tweeter wire with the speaker wire) and that side works.
    What else can i check?
  • McCoolidge
    • 226
    If it doesn't work, chances are it is blown. My driver's side tweeter is blown as well.
    • ummagawd
      • Jul 2006
      • 144
      so i take it that the wiring going up to the tweeter USUALLY is NOT the case?
      • netcsk
        • Apr 2004
        • 1609
        nearly all the time the wiring will be fine.
        It's a good time to replace the tweeters :).
        • ummagawd
          • Jul 2006
          • 144
          hmm.. welp... if i would have known that... i would have bought components instead of 3- ways
          • AndrewBird
            The Mad Scientist
            • 11892
            The tweeter runs off of the speaker in the kick panel. Pull the kick panel off and see if the wires came loose.
