sub/amp install
  • JAM
    • Feb 2007
    • 524
    sub/amp install
    did you guys just run the pos to the pos and the neg to the neg or did you ground the amp out somewhere else?
    i have a feeling for some reason its not good to ground the amp out on the battery...
    Originally posted by Mr Watsonsilver
    driving boards?
  • AndrewBird
    The Mad Scientist
    • 11898
    I think most just ground it to the closest spot they can with a big screw. Make sure you grind away any paint though.
    However, some also believe that everything should be run to the battery directly, eliminating any ground loops. This isn't always need though and is usually a lot more of a PITA.
    • JAM
      • Feb 2007
      • 524
      so if i ground the sub with the - side of the battery my car wont explode or anything?
      lol
      driving boards?
      • JAM
        • Feb 2007
        • 524
        well, i ran it to the bolt where the battery is grounded, not directly to the battery. im pretty sure it should be a-ok
        driving boards?
        • netcsk
          • Apr 2004
          • 1609
          That's the best ground point, to keep the potential difference between the positive and negative of everything the same (of course, it means you should also run everything audio from the positive side of the battery).
          • DSchultz325e
            • Aug 2004
            • 1158
            I made another ground point in the trunk, stripped/ground it to bare metal, screwed it in, and silicon sealed it. If you go that route just be wary of the fuel supply.
            I retired my E30 for now...
            E46 323i
            David Schultz
