when the needle hits the red reserve part on the gauge, the need just falls. and the obc will say somethin between 22 miles left to 25 miles. then it jumps up to 32 m and then finally falls to 9 or 13 and sucks fumes :(. when i fill up the tank the needle will barely go above the 3/4 mark. is my fuel sensor loose or somethin. i dunno maybe someone can help me on this.
fuel sensor?
maybe there is a loose connection or something.
my fuel gauge bobs around liek fucking crazy. i should check the connections too. -
hhmmm, maybe it is something on the fuel tank end of the deal. maybe the sending unit is loose or broken or damaged.Comment
Hey man, I replaced my fuel sending unit along with the in-tank fuel pump a while ago. I can help you install it if you get a new one. If you have the original sensor, you probably want to replace it anyway.
Getting a brand new unit only helped a little though. It's more accurate, but it still moves weirdly from time to time. I think the problem is with my cluster.
Anyway, hit me up sometime.Last edited by brandondan1; 05-08-2007, 04:42 PM.
91 318isComment
