Rattel-Can MDF?
  • george graves
    • 19997
    Rattel-Can MDF?
    I have some MDF (3/4") I am using on a project - Want to spray paint the stuff. The edges are a pain (it's like trying to paint a stack of napkins, it just soaks up the paint.)
    Best I can figure is do 3 or 4 THICK coats of primer first. Any other advice?
    Originally posted by Matt-B
  • AndrewBird
    The Mad Scientist
    • 11898
    Why not just cover it in carpet?
    If you're set on paint, I would either try primer first, or just heavily saturate it with paint. Not really a whole lot you can do. If the cuts are clean and sanded, it will take paint easier.
    • Mtriple
      • 3139
      You can also mix up a little fiberglass resin or bondo and hit the edge. That will keep the paint from wicking in.
      Originally posted by Simon S
      • StereoInstaller1
        GAS
        • 22679
        Bondo or spot putty, whichever you have more of.
        When doing things in paint where the edge shows, or gets painted, I cut a 45 degree angle piece off, rotate it 180 degrees and re-attach using a cabinet stapler and glue, thus showing a tiny seam vs. a full butt.
        Closing SOON!
        Thanks for 10 years of fun!
