how do i fix the low beam check relay
  • homegrone30
    • Jun 2007
    • 1449
    my low beams dont work the bulbs are good but are gettin no power so i got wiring diagrams and ive traced the problem bu the wiring diagram states that the low beam check relay is part of the printed circuit board.
    has n e one had to fix this if so teach me
  • atomic
    • Jun 2007
    • 5691
    it is easier to start simple. have you checked your fuse ?? if good then it could be the relay. if good then check the headlight switch once you know all that is good then you dig further.
    • homegrone30
      • Jun 2007
      • 1449
      ive done all that i have two headlight switches ive checked all fuses and no disrespect but i asked how to fix the low beam relay just cause it says noobie dont mean shit i know what im doin i just havnt felt like ripping apart the fuse box to find it.
      • E30 Reaktionär
        Site Manager
        • 14451
        The relay is internal? or is there two of them?
        1992 BMW 325iC
        1978 Chevrolet Monte Carlo
        • atomic
          • Jun 2007
          • 5691
          Well go fuck yourself then I just wanted to make sure the easy stuff was out of the way first. Since I have fixed this before go figure it out yourself since you know so much. :ohsnap:
          • homegrone30
            • Jun 2007
            • 1449
            wo man leave your big boy boots at the office no disrespect means just that NO DISRESPECT so slow your roll i aint trying to piss on your parade everyone knows to go through and check fuses then grounds then switches if all thos fail search for power
