hahahahahhahaahaha omg....isnt that high risk of buring your car to shit?
help!fuse 10 keeps blowing and i have no guages!
OK, so no other fuses are blowing, just fuse 10, right?
Have you checked your unloader relays with known good ones, see if they are causing the problem?
Systematic testing is your only hope. You could remove the fuse and replace it with a voltmeter while you do the testing, but if something is going to fry, this is when it will do it... I'd recommend just picking up a big handful of 7.5A fuses and working through this.John in MD - 1991 318is
190k miles and still rolling!
Uhh... in the middle of the fuse box...
The lid should tell you which is which, but if you don't have one (which you should rectify), K5 is the forwardmost one on the left/driver's side of the car, and K7 the third one back, or second from the firewall, again on the left/driver's side.John in MD - 1991 318is
Wait, I just had a brain fart. My 318 was doing the same. I finally found out that the dryer was locked up. I unplugged it and the problem was gone. At least give it a shot.sigpicComment
lol wait a sec im confused on that last post haha, you had a brainfart and the dryer in your head was locked up????
or the dryer in the relay??
do you mean take out the load reduction relays one by on and see if that makes a difference?M stands for Money:hitler:Comment
If it is an AC component, the unloader relay is not doing it's job - the relay should separate those heavy draw components from the fuse 10 circuit.
Pull the relays and rule them out. Then, proceed to the fun part - chasing wires.
First thing I would do if you get to this point is check each and every termination of the circuit for continuity to ground, maybe you'll get lucky and find an obvious one.
Then, leave everything on the circuit unplugged, and, one by one, plug them back in. As in, plug one in, turn it on and see if it blows the fuse, then unplug it and move to the next component. Maybe one of the components is drawing too much current.
It would suck to have to physically trace each wire, but it can be done.John in MD - 1991 318is
absolutely... I knew a friend in high school... his name is cough cough "essi" yes he's persian. He instal some speakers and didnt uprate the wire and jsut hook up a higher amp fuse... He's car burns to a crispy nothing... literally, went over adn his car was in flames everything, before the firewall aka engine etc was fine, everythign in the back is just black charcoal.Comment
fair enough...ok...some obvious things that i cant unplug are...starter...fuel pump....hmmmm because it states fuse 10 is connected to them...i have unplugged almost every component except the starter and fuel pump...........i was also noticing on the wiring diagram that the seatbelt check and control unit are linked to fuse 10...ill unplug that unit(it is mounted behind the abs unit right????
regarding fuel and starter....can i just unplug those relays as well??? and try a fuse?
my whole a/c system is removed...by the way
thanks alot guys for your helpM stands for Money:hitler:Comment
checking as we speak...yes their hanging but by no means touching any part of the body and the ends all have housings around them...M stands for Money:hitler:Comment
