anyway of keeping atenna on while having aux playing?
  • steinbachphoto
    • Aug 2007
    • 914
    So as you all know when you turn on your deck your antenna pops up, and honestly mine is an eyesore, its like a man that took male enhancement pills and something really wrong happened and it got all warped and bent at the top of( but when its down it looks fine).
    and even when I'm not using the Tuner and have a cd or ipod plugged into the aux the antenna stays up, but i don't want it to, is there anything to change that? I wasn't able to find anything on my HU which is a Kenwood KDC-MP2035. or is there a sensor i can trick or something, because i don't think I will ever listen to the radio in my car.
    http://www.steinbachphoto.ca
  • steinbachphoto
    • Aug 2007
    • 914
    and i totally screwed up the title!
    • ak96ss
      • Nov 2005
      • 461
      Pull the deck out and cut the blue wire, or put a switch inline. Unless you are using the antenna wire as the remote turn-on wire for amps, at which point you'll have to wire the switch in after it turns on your amps.
      John in MD - 1991 318is
      190k miles and still rolling!
      • Mtriple
        • 3139
        or buy an Alpine!
        Originally posted by Simon S
        • steinbachphoto
          • Aug 2007
          • 914
          Originally posted by SuperDuper
          or buy an Alpine!
          why would an Alpine benefit me?
          • Mtriple
            • 3139
            Alpine has a dedicated output just for power antenna's. This output is only energized when you are using the tuner portion of the head unit. Anything else and the antenna stays down.
            • steinbachphoto
              • Aug 2007
              • 914
              every model? I already have a kenwood one though. Do you think I should actually switch?
              • thereisnoyun
                • Feb 2007
                • 2301
                panasonic
                I just did my gf's the antenna signal has it own output on the harness as well, so it only turn on when stereo is on... If your HU doesnt do it, then like john say, wire a switch.
                • steinbachphoto
                  • Aug 2007
                  • 914
                  i think i may just cut it.
                  I don't have the know how to install a switch....
                  but say later on I am installing a sub and amp, do i have to use the antenna to turn them on or something? Im confused
                  • StereoInstaller1
                    GAS
                    • 22679
                    OK, first, pull your deck. Look and see if you have a blue with a white stripe.
                    That wire is your dedicated power amp turn on.
                    IF you are still using the stock amp, you will need to leave that blue wire connected to turn the amp on, so simply pull the trunk liner down and unplug your antenna.
                    When you do your aftermarket sub/amp/whatever, you will use the blue/white or the blue, (depending on what your deck has) to turn them on.
                    Oh yeah...most Kenwonts...er.....Kenwoods have that blue/white wire. Most aftermarket decks these days do, except Pioneer.
                    Luke
                    Closing SOON!
                    Thanks for 10 years of fun!
                    • steinbachphoto
                      • Aug 2007
                      • 914
                      Luke
                      okay so I just went out and bought a sub and amp system. its not hte best quality but it will do what i need it to do..
                      I got an 12" Infinity sub(1250W), bassworkz sealed box, and a Rockford Fosgate P200-2 amp. So is it still okay if i disconnect the antenna?
                      • xLibelle
                        • Aug 2004
                        • 2673
                        Luke
                        Oh
                        • steinbachphoto
                          • Aug 2007
                          • 914
                          bump
                          • ak96ss
                            • Nov 2005
                            • 461
                            How do you plan to turn the amp on? If you need to use the antenna power as your remote turn-on for the amps, your best bet is to either disconnect the antenna at the antenna, or install a switch after the amps.
                            • StereoInstaller1
                              GAS
                              • 22679
                              Run a new wire to your amp is the logical solution. Especially if the deck has a seperate amp remote wire.
                              You need to run RCAs anyway, why not do it at the same time?
                              Luke
                              Closing SOON!
