Trying to hardwire V1 into 318is...
    ~on the left is the phone line
    ~on the right is the 318 Check Panel
    ??? ~~ Which wires do I tap into to get this thing hardwired?
    Thanks guys.
    Toyota Pickup
    eww there's buggers coming out of your rear view mirror
      I like what you're trying to do, however you might want to consult wiring info wherever you got the idea this was going to work.
      Also, are you planning to retain a fuse inline? It would bite if you blew out a Valentine. Possibly a fuse holder can stuff in behind the check panel?
      It's not how you handle the good times, but the faith you keep in the bad that defines you.
        V1 comes with a kit that can be used to hardwire it. I put the little box that wires into the power, and has the phone line connector underneath my steering column. Then I ran the phone line up the a pillar, and ran it out above my mirror. Nice thing about this is, I can get a concealed display someday, and I'm alreayd ready to plug it in.
        Just find a 12v source and a ground - that's all you need. Find the V1 hardwire kit - shoulda come with the v1.
        - Sean Hayes
          i don't believe there is a constant 12v from any of the wires in a 318is check panel. try to pull power from the dome light, or do what sean suggested and pull power from the dash, running the wire up the a-pillar. good luck.
          My transaction feedback thread(s):
          http://www.r3vlimited.com/board/showthread.php?t=292029 :up:
          http://www.r3vlimited.com/board/showthread.php?t=329392 :up:
            there is
            i had to use a probe cause it wasnt the usual purple/brown suspects but i did get it to work. i'll look tomorrow.
              My box is chilling by the ECU, the phone cord is plenty long to reach your V1's new home.
              I am in the Land Cruiser right now, so I cant look at what I tapped into, but the install was super easy with mounting it there. (plus it is switched with the key, which you want)
              Joe Funk -- Portland Oregon
              That Guy.
              03 X5. 3 liter obviously.
                I responded to the exact same post on M42club.com, but FWIW:
                You can tap the green/white wire, it is +12V in start or run off of fuse 10, 7.5A. The violet wire is hot all the time, the brown/black one goes back to the SRS diagnostic module, and the brown/violet one goes to the seatbelt warning timer.
                John in MD - 1991 318is
                190k miles and still rolling!
                  Is there enough room up there for the module?
                  That Guy.
                    No idea - I stopped using radar detectors years ago, so I have no clue how big the module is. But you could probably fit a pack of smokes up there (roughly), so as long as it is about that size or smaller, I would imagine you would be OK.
                      Yea, the connector box could fit up there.
                      - Sean Hayes
                        I'm lazy so I took apart my knee bolster and ran a cable through it and up the a pillar which pops out by the rear view mirror and then I just plug it in to the cigarette adapter. Saves me wiring hassle, no stray cables running amok, and if I need to turn it off and not piss off a cop I can just reach over and unplug it, no need to reach up and look suspicious.
                        Who doesn't love a little BBQ?
                        Griot's Garage at a Deep Discount
                          thanks guys for your inputs...
                          so which color wire goes with what?
                          Check Panel - BROWN, PURPLE-BROWN, PURPLE, GREEN-WHITE
                          Phone line - BLACK, RED, GREEN YELLOW
                          Toyota Pickup
                            RTFM and tell us what each wire in the phone line is supposed to be - off hand, I would say a radar detector would need +12V and ground - what else is there?
                              i just saw your post on M42, thanks for the reply. I am trying to figure out which wire does what from a friend that wired his e36.
                              Toyota Pickup
