http://www.trademe.co.nz/Browse/List...x?id=127130092
specs:
* 111W RMS x 4 channels at 4 ohms and 1% THD + N
* Signal-to-noise ratio: 81dBA (reference 1W into 4 ohms)
* 139W RMS x 4 channels at 2 ohms, 14.4V supply and 1% THD + N
* 278W RMS x 2 channels at 4 ohms, 14.4V supply and 1% THD + N
* Dynamic power: 164W at 2 ohms
* Effective damping factor: 6.315 at 4 ohms
* Frequency response: 10Hz - 100kHz (-3dB)
* Maximum input signal: 5.5V
* Maximum sensitivity: 75mV
* Output regulation: .088dB at 4 ohms
* Dimensions (L x W x H): 12" x 15" x 2-11/16"
* Fuse rating: 2 x 30A
Would be planning on running dedicated 4 channel splits up front, with a n audiocontrol 6xs crossover.
Should I be concerned at the s/n ratio?
specs:
