Where is the engine block to chassis ground located on the 325i? I am doing a big 3 wiring upgrade and I am having trouble locating this wire.
Engine block to chassis ground
Tags: None
Driver side front. Goes from the chassis to the oil pan I believe. It's a non-insulated flat braided cable. -
ehh, sort of. ;)
It's *supposed* to be an insulated wire- sort of a light brown color insulation- though alot of them seem to have lost their insulation over years of exposure to oil and the elements..... It is on the driver's side, towards the front of the oil pan, it attaches to a threaded stud on the frame rail down low.
BretComment
if you think thats going to get rid of your whine, good luck.
Doing something M50 related? -> http://www.addissimo.com
On Myspace? ->http://groups.myspace.com/r3vlimited
BF2142 SN = BillyGooseComment
No alternator whine, but all of my lights are pulsing. I think its probably a voltage regulator, but I've had this big 3 kit sitting around forever and it will probably help when I install a larger amplifier.
For those who don't know, big 3 is upgrading the battery to chassis ground, engine block to chassis ground, and battery to alternator wires with larger gauge wires, for increased electrical flow.Comment
Go get a half-farad cap and install it on your headlights.
Big 3 won't do shit on our cars...ricer crap only.Comment
Oh yeah...and ground your amp at the battery. Only car I would ever recommend that on is a rear battery BMW, but trust me, it helps.
LukeComment
Status: HG repair. 488wtq though!Comment
If your ground wire is fucked up, by all means, replace it. Duh, right? However, they guy who did that page should have used a wire equivalent in quality to BMW, if not better, rather than using cheapass auto parts store junk. In 5 years that wire will be toast, OE stuff will last 20 or more...
"Big 3" generally refers to the supposed ricer trick of re-grounding the block to make you car run better...these 'tards seem to think it actually is faster with a new motor ground.
I suppose if you have an 18 gauge body ground, or a chunk of pink 16 ga speaker wire grounding the block, you might be better off using a real ground wire, but the ricers swear that the "big 3" will make the car smoother and faster...I say bullshit.
LukeComment
The one I am thinking of I KNOW is uninsulated. It looks just like the one connecting the hood to the body. Flat and braided.ehh, sort of. ;)
BretComment
like the hood ground cable i assumeYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by TimKninjaIm more afraid of this thread turning into one of those classic R3v moments, where Pizza gets delivered.Comment
So the guy on the slidewayz (y0!) page is replacing a fucking bas ass groundstrap with a cheezball 4 gauge ground and expects it to be an improvement?
I don't think so Bob.
I know my block ground is just fine.Comment
I later replaced it with audio grade wiring but it wasnt supposed to be an improvement. It was a fix for the starter not grounding enough to kick over the motor as a result of the dead stock wiring. It might not last 20 years but the stock one obviously didnt either.
