someone want to help me ID random wires that arn't connected to anything?
  • scobaru
    • Nov 2007
    • 396
    So the project car has a few wires that don't connect to anything.
    the first picture shows the front of the car on both sides they are the same.
    I located the high beam and low beam headlights, turn signals and fog and theres 2 extra wires that are cut that don't go to anywhere.... they where in the fog lamp area the red circle is what its pointed to
    the next picture is inside the car. theres a white harness thats circled that comes off of the turn signal stalk thats not connected to anything but taped there. and the 2nd circle are 2 harnesses that don't connect to each other and don't connect to anything at all
    a lot of things don't work on the car so if any of these might have something to do with it that'd be great!
  • buhnahnuh
    • Nov 2007
    • 69
    So the bottom picture on the right circle if I am not mistaken that plugs into the kick panel and goes into the chime. So when doors are open it will chime
    and the first picture might be the temp sensor? Not sure about this though or maybe the HORN who knows
    • scobaru
      • Nov 2007
      • 396
      I have 2 of them on each side that are near the fog lamps... the horns do work so I think that isn't what thats for. but the Chim would make sense since theres no chime and the guy had the panel off when I picked up the car
      • AndrewBird
        The Mad Scientist
        • 11898
        Does the car have fog lights? If so, I would think the top picture is plugs for the fog lights. I'm pretty sure all e30s came pre-wired for fogs, even if they didn't have any.
        • scobaru
          • Nov 2007
          • 396
          in the picture I'm holding the fog lamp harness theres an extra set of wires near the fog lamp area
          • DaveSmed
            • Apr 2007
            • 1406
            Do your sidemarkers light up? what your holding looks like the sidemarker harness. I cant tell what that other plug is, is it round?
            -Dave
            2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
            Need some help figuring out the ETM?
            • buhnahnuh
              • Nov 2007
              • 69
              definetly a sidemarker light is what you are holding. I think those wires are for fog lights and could be mistaken, if they are on both sides then they most likely go to the same thing I will check my wires and see ehat wires are there. What color are the msterious wires-if you let me know I can get a better idea
              • scobaru
                • Nov 2007
                • 396
                okay I think you guys are right.
                what i'm holding is side marker lights and the other wires are prob fog
