Amp question, StereoInstaller1!! :)
  • equate975
    • Jun 2004
    • 3382
    Ok, I am specing out a system for my jetta. But I got a quick question. First off heres the setup
    Phoenix Gold RSD front speakers (no gonna use any rears)
    RE SR12 Sub (DVC available in 2 or 4 ohms)
    Candence TXA-6004 4chan amp
    This website is for sale! cadencestore.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, cadencestore.com has it all. We hope you find what you are searching for!
    Should I get a 4ohm DVC sub, bridge 2 channels on the amp, wire the sub in parallel for 2ohms, and put that onto the 2 bridged channels? That should be 2ohms at 600w for the sub right? Then with the other 2 channels I can drive the speakers off that at 4 ohms.
    Or, should I get a 2ohm DVC sub, don't bridge the channels, and just hook each voice coil up to a channel? Wouldn't that be the same thing?
    Also, can I even do any of that? Just wanna make sure lol.
    Rollin' with a Geistkuchen
  • StereoInstaller1
    GAS
    • 22679
    Nope...if you are gonna run just that amp, use a DVC 2 ohm per coil, so you end up with a 4 ohm mono load to 2 channels, then the components on the other 2 channels.
    If you try 2 ohms mono, that is the same as 1 ohm per channel, thus smokeage of amplificator.
    later, if you decide to upgrade, you can buy a 1 ohm stable mono sub amp to drive the sub, then you would use 2 channels of the 4 channel to run the mids, the other 2 channels to run just the tweets, with an external 3 way crossover.
    BTW, I though you didn't believe in stereos?
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
    • equate975
      • Jun 2004
      • 3382
      Awesome thanks!
