rear driver side window
  • jrobie79
    • Mar 2006
    • 2525
    my rear window does not roll down with its own switch, but it will roll down with the switch in the center console, i know its not a bad switch because i have swapped a known working switch in the back door. i probed all the wires and there is continuity and voltage, so i dunno whats up maybe the motor or something? but that would cause the front switches to not work. also for the front switches to work there has to be a switch plugged into the rear slot or it doesn't work.
    1991 318i ---- 308K - retired
  • delfin
    • Nov 2007
    • 1064
    Check the circuit breaker, the one by the shifter, little black button about half the size of a window switch. It lets you roll down from the front but not the back
    Advanded Delphin Division
    My e30s: 1987 325i/1994 318iT
    • jrobie79
      • Mar 2006
      • 2525
      yeah i saw that, i thought i tried it, but i could be mistaken, i thought i had rolled down the other side window and couldnt roll down the driver side rear, but ill check again tomorrow. thanks.
