wacky coolant temp gauge
  • scobaru
    • Nov 2007
    • 396
    so the coolant temp gauge on my e30 will jump back and forth and is almost never accurate. I've heard the solder just becomes old and will just wear away. I have the cluster out since I'm doing some other repairs does anyone know exactly needs to be fixed or re soldered ?
  • redhatpat
    • Aug 2005
    • 656
    Have you confirmed the sensor is good?
    • wagonizzle
      • Sep 2006
      • 443
      Check and see if the ground nut on the gauge is tight...
      Originally posted by chileelky
      amaze about the enthusiasm e30 generate
      • scobaru
        • Nov 2007
        • 396
        I'll check the ground nut on the gauge. and i haven't confirmed the sensor is good but on the last 3 e30's I've looked at/owned they all had the same problem. I know its some what a common problem on E30's thats why I though I'd look. if the sensor is bad it'd throw really crazy signals since the gauge shoots back and forth which wants me to believe its more of the cluster problem but i'll take a look
        • dougsic
          • Jun 2006
          • 284
          This is the problem. The two brass nuts on the back of cluster ground it. They work loose and the temp gauge and/or the fuel gauge becomes jumpy.
          • scobaru
            • Nov 2007
            • 396
            I took the cluster out and I found my problem circuit board needs some soldering
            • gearheadE30
              • Jun 2007
              • 3734
              I've never seen a trace burn there before...
              Project M42 Turbo
              • bignate948
                • Apr 2006
                • 542
                i have the same problem with my gas gauge. where are these brass nuts that ground it?
                • txleadfoot
                  • Apr 2006
                  • 208
                  The brass grounding nut was the issue with my jumpy temp gauge. Now it reads correctly. There is one nut in this photo:
                  • JinormusJ
                    • 6887
                    Bumping this because I have a question; temperature gauge likes to flop around; when replacing the nut (because mine fell and is no where to be found; does it have to be brass? Or does it just need a nut there?
                    • dudecati
                      • Jun 2012
                      • 104
                      I just replaced mine as it was missing too. I went to the local hardware store got a nut AND lock washer, tightened it all up and it works like a charm. The replacement hardware was not brass.
                      • JinormusJ
                        • 6887
                        Sweet; exactly what I did, and mine is not brass either; was just about to run out to a different local hardware store and try my luck for brass fittings, but since material is not a necessity, I'll make due
                        Thanks
                        • noid
                          • 1537
                          On my first E30 my temp gauge would jump around erratically, it ended up being the oil pan to body ground.
                          Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
                          Your resource to tools and tips: www.rtstools.com
                          • izickc
                            • Feb 2013
                            • 59
                            i am having this issue too,,,, i have replaced the cluster and its still happening, where is the sensor that connects it to the engine located?
