ok, so I have no clue...
  • Shift_Now
    • Jun 2007
    • 91
    well I;ve tried other places to find this information, and so far no luck. Well I'm looking into buying a single voice coil sub, and its rated for 4 ohms. But my amp is rated at 2 ohms. Would it still sound good and be safe to run this set up "as is"?
  • DaveSmed
    • Apr 2007
    • 1406
    Yes.
    -Dave
    2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
    Need some help figuring out the ETM?
    • StereoInstaller1
      GAS
      • 22679
      Is your amp a 2 channel?
      Closing SOON!
      Thanks for 10 years of fun!
      • Shift_Now
        • Jun 2007
        • 91
        yes, its a 2-channel. I could bridge it to bring it up to 4-ohms, but I was told it is better to run the amp at lower ohms, as long as it is still stable there.
        • StereoInstaller1
          GAS
          • 22679
          4 ohms bridged is 2 ohms per channel: the amp sees the load on both channels.
          Any lower is going to blow the amp up sooner or later. Use a 4 ohm load ONLY.
          Luke
          Closing SOON!
          • Shift_Now
            • Jun 2007
            • 91
            really? ok, sounds like a plan. Thanks Luke.
            • TheEtaUnderdog
              • Jun 2007
              • 841
              he has a single voice coil sub rated at four ohms. I don't care how he bridges it, the amp is seeing only 4 ohms. Its stable and he's good to go
              Are you kidding me? That nerd doesn't even know how his dick works, let alone a car.
              • TheEtaUnderdog
                • Jun 2007
                • 841
                Now if he had a DVC sub or 2 subs, then he starts running in to the ideas of parallel or series, and bridging or indepent channls. But as is, bridge the channels and it will see 4 ohms all day long. Now if u have a reallllllly pimp amp like the Incrimanator Audio 20.1 you can see .5 ohms or lower all day now and not worry :-D
                • StereoInstaller1
                  GAS
                  • 22679
                  Wait, what?
                  4 ohms mono = 2 ohms per channel...that is the correct answer.
                  If you think otherwise, go read and learn. You will find I am correct.
                  Luke
                  Closing SOON!
                  • ejnight
                    • Apr 2007
                    • 3488
                    Wait, what?
                    Luke
                    you are both saying the same thing and are both right.
                    http://raceskids.com/
