i icm in a e
  • SamE30e
    • Sep 2007
    • 4319
    i icm in a e
    Will a 325i ICM work for a 325e?
    Thanks
    Sam
    1985 325e 2.8 Turbo VEMS
  • Jean
    • 18228
    Somehow I doubt it.
    • Teaguer
      • Sep 2004
      • 6167
      Only if you switch the whole harness over along with all the other essential bits so the DME thinks its running an "i' engine .
      Probably NOT what you are wanting to do . ;)
      There are plenty of Eta DME's on the boards for sale and they go for junk since Etas are crap .
      • Jean
        • 18228
        Sig material right thur. :)
        • Teaguer
          • Sep 2004
          • 6167
          They are about neck and neck with M10 318's though . :p
          • netcsk
            • Apr 2004
            • 1609
            The 325i doesn't have an ICM. The ICM on the eta is the green box next to the ecu.
            • James Crivellone
              Head Janitor
              • 6305
              If you had an 88 325 SuperETA then you could run Motronic 1.1/1.3, however 84 - 87 E's use Motronic 1.0, which has a dual row ECU connector, completely different electrically from the newer models.
              The ICM is only present on 84 - 87 E's as well, I's/SuperETA's never had it.
              • Jean
                • 18228
                Lol, hey at least it revs to 6.5k all day long. It does only get me 20-22mpg though ...
                • SamE30e
                  • Sep 2007
                  • 4319
                  I think everyone thinks i'm talking about the ECU, not the ICM. But thats the answer I was looking for. Thanks.
