Bandpass in that tiny trunk? I wouldn't think so....plus woofers that work well in bandpass are hard to find.
Subwoofer Install Tutorial: TONS of pics, none of my buttcrack
Very true. Last one i liked was the orion extreme.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
My euro 316 project Transaction FeedbackComment
JBL GTi1200 in 4 cubic feet of bandpass...clean and fucking violent.
I also did 2 XTR DVC 12s in 6.5 cubic feet bandpass tuned for LOUD...hit 148db at 52Hz on 88 watts of Autotek. Well, actually half of that because it was a 4 channel running the whole car ('79 Monte)
Would not play ANYTHING below 35Hz, but unbelievably loud above that.Comment
If you have a non-armrest seat, do you need to cut out all of the foam from in front of the woofer? My seat looks perforated but it is not, theyr'e just dimples. I was thinking of cutting a hole in the seat and trimming the opening with vinyl or something. Has anyone done that?
Tom"Life is hard...it's a lot harder if you're stupid."
Tom
72 2002
87 327i
88 525i
88 535i
03 530iComment
Tim, the ports are a pain in the butt to get in because they are so damn tight.
I use a cardboard tube between the plastic trim port adn the ABS coupler in the box to assure a tight fit.
There is no cardboard available that fits correctly (that I can find, anyway) so I trim both the inside and the outside to make it fit.
Tom, as far as re-working the rear seat....well, I highly recommend finding an armrest, that much I can tell you. I am not an upholsterer, nor do I pretend to be one...no sewing machines here, I can tell you. I am sure that anyone competent in auto upholstery can handle it just fine.
LukeComment
If you look at your picture of the box where you are drilling the hole, down to the lower right of the box there is a "port" looking hole. is that what it is?
if it is why is there two? the ones you made custom in the stock speakers, and the custom box port?
and let me get this straight, there is just front speakers and a 12?
nice!Comment
In that picture, the box is on it's back/side. The hole is one of the ports that go up through the rear shelf.
And yes, front speakers, meaning tweeters and mids, and a 12" sub. That is all you need in an e30.Comment
So what would be an optimum, cost effective sound setup, assuming one can get a hold of one of Luke's super boxes?Originally posted by csermonet47Vlad, you are handling this quite unprofessionally.
Also, you are a cock with tacky taste.
That is all.Comment
I called up luke and told him what I had to spend - and he sent me the best he could. It included a box, sub, components, tweeters and wiring. I already had a HU."We praise or find fault, depending on which of the two provides more opportunity for our powers of judgement to shine."Comment
Cost effective? Stock premium sound up front, but using aftermarket 2 way crossovers.
A cheap 4 channel amp with variable crossovers.
A cheap SVC 12" sub, with a Qtc under .5
Fronts speakers run off of half of the 4 channel, the other 2 channels bridged to the subwoofer.
Including deck, you could have great sound for under $600 using my box (about $200 shipped, typically)Comment
Josh, an armrest is basically the same as tripling the subwoofer power.
If you can, do it. If you can't, do it anyway.
I got mine from an '85 325e, my 87 325is didn't have one. It was shabby, so I got leather paint from Select Products and painted it. Looks great, a year later.Comment
