E-30 Electrical Gurus...help needed
  • Nick
    • Oct 2006
    • 279
    We're building an E-30 racecar for a customer.
    The car is pretty much ready, mechanically speaking.
    There are a few minor electrical issues that need to be resolved.
    The car is currently running the standard motronic unit.
    It has an aftermarket fuel pump, run to switched power.
    The coil and ignition system have also been altered to run on switches.
    The problem we are facing is that someone else did earlier electrical work on this car, and the car will not run with the current setup.
    The fuel pump works, the car will crank...but we have no spark.
    There is power to the Motronic, and power to the coil.
    Basically, what are the MINIMAL requirements to achieve spark, (what wires need to go where) and what are the overall MINIMAL requirements for the Motronic to operate the injectors?
    Please be as detailed as possible, Motronic pin positions and wire color codes would be great.
    Our build specialist is a BMW Certified Mechanic, and he's been working on the car off and on for a few weeks, and tomorrow afternoon a consultant from the BMW Dealership is coming to take a look at it. We've tried two different Motronic ECUs, we get continuity on all connections, so we're not quite sure what's wrong.
    Here's what we're dealing with:
    We'll be replacing the existing switches and routing them to a master panel in the dash we fabricated, and the wiring will of course be re-sleeved and routed through conduit. We're looking to eliminate the fusebox and C101 also.
    Any help would be appreciated, thanks.
  • DaveSmed
    • Apr 2007
    • 1407
    The car not running is a minor issue? :p
    What year engine harness?
    -Dave
    2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
    Need some help figuring out the ETM?
    • Nick
      • Oct 2006
      • 279
      It's an 89 325i.
      LOL, it's minor...relatively speaking.
      • DaveSmed
        • Apr 2007
        • 1407
        Ok, pin #7 of C101/pin #27 DME..... Battery voltage with key on?
        -Dave
        • Nick
          • Oct 2006
          • 279
          Check.
          This is Green from Coil to Motronic and Ignition? There's power there.
          • StereoInstaller1
            GAS
            • 22679
            Nick, do you have the BMW electrical manual?
            Closing SOON!
            Thanks for 10 years of fun!
            • Nick
              • Oct 2006
              • 279
              Yeah, we have the BMW ETM for the E30.
              Which makes it kinda embarassing that we can't get this car started.
              • DaveSmed
                • Apr 2007
                • 1407
                Damn, that pin 27 is usually it.
                Ok,
                Key on engine off, DME unplugged, you want power at:
                27
                1
                18
                37
                You want ground at:
                19
                14
                24
                2
                -Dave
                • StereoInstaller1
                  GAS
                  • 22679
                  Yeah, like me not being able to remote start my buddys GFs 02 Grand Prix? Fucking GM databus crap is worse than any bosch doo-doo, but I do feel your pain.
                  Go VROOM, dammit!
                  Closing SOON!
                  • Nick
                    • Oct 2006
                    • 279
                    The guy from BMW is here now. For some reason, the coil is hot at the ground...so we're baffled. We have a BOB test box and the computer has ground and power at all the right places. We don't have internet access at the shop yet so I have to do this from my phone.
                    • Nick
                      • Oct 2006
                      • 279
                      We figured out that that's normal and might be making progress
                      • DaveSmed
                        • Apr 2007
                        • 1407
                        Ah was just gonna say, that means at least the primary is working! (and its also why I said there should be voltage at terminal 1 above, thats the wire for the "negative" of the coil)
                        -Dave
                        • Nick
                          • Oct 2006
                          • 279
                          Yeah, the BMW guy had to think for a minute to remember how the old ignition systems work.
                          Even I couldn't remember, and I've done engine swaps in the e30 before.
                          Right now we think we may have a bad crank pulse sensor. Or maybe the wiring harness is boogered up some other way.
                          If the guy from the dealership can't get it to work this week, (and if anyone is relatively local), we'd consider paying someone like $20/hr if they think it could work.
                          I actually had my camera today, so here's a decent picture of the car in question (plus a few extras)
                          • DaveSmed
                            • Apr 2007
                            • 1407
                            Ooh, eye candy! sweet bonus.
                            Anyway, just thought of something. There are two three pin connectors under the diagnostic plug. Swap them. Any change? If not, swap them back.
                            -Dave
                            • Nick
                              • Oct 2006
                              • 279
                              Those would be the....pulse sensor connector and...I forget what the other one does off the top of my head.
                              I want to say coolant, but I know that's not right.
                              We tried that already! I can remember having that problem when I did my 'e' to 'i' swap way back in 2000.
